Microcontroller: STM32F302R8Tx MDK-Lite: v5.26 DFP: 2.1.0 STM32CubeMX 4.27.0
I am running into an issue where the Keil uVision and STM32CubeMX are not using the same HAL library version.
- In Keil uVision, under "Manage Run-Time environment -> Device -> STM32Cube HAL" the HAL version is 1.9.0.
- In STM32CubeMX, the most recent HAL version is 1.10.0.
This makes it impossible to use Keil uVision to generate a STM32CubeMX project because the code generated by STM32CubeMX is based on HAL 1.10.0, while the HAL library inside Keil uVision is still on 1.9.0. Is there a way to force uVision to use HAL 1.10.0? Or do I have to wait for an update from Keil?
