OneDrive sharing violations after upgrading to uVision5
I finally upgraded from uVision4 to uVision5 and now I'm encountering a frequently
reoccurring error when building. The errors are file sharing errors from my project folder,
which happens to be a Microsoft OneDrive folder. I never had any issues with file sharing
errors with projects in OneDrive folders while using uVision4.
Is anyone else experiencing this? Anyone know why this is happening, and how to fix it?
It's quite annoying, because my edits are not being saved. I've temporarily resorted to
manually moving projects from OneDrive to a local drive (while working on them); but that's
a pain because I have to copy everything back to OneDrive every so often, or at least when
I'm done for the day.
Thanks.
  • Hello David,
    In this forum thread:
    http://www.keil.com/forum/63974/
    They said:
    MDK development team is working on a solution now.
    This "sharing violation" issue should be fixed in the next MDK release (newer than MDK v5.26))
    ... so I say you should create a support ticket for this issue, so that Keil Tech support can send you an updated version of the uv4.exe
    That pre-release executable should fix your issues.
  • Hello David,
