compiler: keil IDE: simplicity studio problem: when put while(1); in the main function of a project and build the project it shows the error 'map target label L42 failed' in the code section which follows it within another while loop. Even that line of code is commented the same error occurs in immediate next line.
Why not show the code?
Indeed.
And the full text of the actual error message.
And tell us when & where, exactly, it appears.
"IDE: simplicity studio"
So Silicon Labs, then.
I think their forum has better facilities for posting screenshots, etc?
If you do post there, remember to give a link there to this post, and a link here to that post...
surely, Link: www.silabs.com/.../map_target_labell42-mhFq
Thank you
Your SiLabs forum post shows that the error is C253
The compiler manual contains a list of errors:
C253: http://www.keil.com/support/man/docs/c51/c51_c253.htm
Also from the SiLabs forum post, it looks like this is happening in SiLabs-provided code?
