Hi Team,
I just brought the Imbuent 8051 Development Board and its really cool. it was recommend by my best friend. now got 3 board and purchase the SK6812 LED strip with 64 on it, How to turn OFF and ON single LED in strip, How to set R,G,B color in single LED, Please provide me any links for secure source code available in c code. no encryption yet.
Regards, PH.
I was have told using the SPI to control those neopixel.
It should work! I know the advantage of the SPI. it has timing!
i need the secure c code for SPI with the neopixel bits.
Regards, PH
You pay the team? Or we do homework for free? Much expectations
Signalling protocol for LEDs cdn-shop.adafruit.com/.../SK6812 LED datasheet .pdf
"Imbuent 8051 Development Board"
So why have you chosen 'ARM' as the Architecture, then?
"it was recommend by my best friend"
So why don't you get your best friend to help you with your homework?
"I was have told using the SPI to control those neopixel."
Who told you that?
Does that correspond to what the SK6812 datasheeet tells you?
Or what the many articles, tutorials & examples available on the interwebs tell you?
Hi Team.
I can put secure C code in my 8051 development board. When i use secure C code it will work in lots of different cprocessor cpu boards.
what i need is secure C code to talk to the SK6812 LED strip with 64 LEDS and i know the SPI can control the neopixel because it has timing.
now how to turn OFF and ON single LED in strip, How to set R,G,B color in single LED.
plz if you have secure source code available in c code can you send to me.
i do not want including no encryption yet.
That makes no sense at all.
But, if you're convinced that you can do it, then why don't you just get on with it?
It's not like there's a shortage of projects already published on the interwebs for controlling these things ...
None of this has anything to do with Keil.
I don't understand all the references to secure and encrypted, and WTF that has to do with driving LEDs
But does it have rhythm ?
i mean secure C code that works and is not bugged.
I mean encryption so to stop people copying it everywhere
i mean timing for the SPI to use it
and i need secure C code to do the ON and OFF the 64 LEDS and set to the R,G,B color in single LED.
i start try code but it bugs in compiler.
is it more difficult?
Given that there is already plenty of code available for free all over the interwebs, why would anyone want to copy it?
I now written some code {got from the internet} but it doesn't working.
Can you look and tel me what they did wrong.
\\MadeInHeven\my computer\users\heven\code\keil\code\c\my code\ardiuno\sk6821\main.c
www.catb.org/.../smart-questions.html
"\\MadeInHeven\my computer\users\heven\code\keil\code\c\my code\ardiuno\sk6821\main.c"
Is it actually an Arduino supported by any Keil tools?
It has been quite a while since I got so entertained by a thread :-)
truly a thread made in heaven!
:D
That has to be the shortest self-contradiction this year, in this forum...
Hi friend,
How can i use SPI to control sk6812 rgbw led strip,do you have some code for it?
