It says: 1) your code preserves 8-bye alignment of the stack. 2) The linker checks that any code that requires 8-byte alignment of the stack is only called, directly or indirectly, by code that preserves 8-byte alignment of the stack.
I need an explanation for the two items,as I read through the knowledgebase, I couldn't come to a clear meaning .
