I use the serial logging feature (SLOG) in the debugger of uVision (V5.24.2.0).
I want to switch on and off the serial logging, controlled by the running code. My intention was to use a user function each like:
FUNC void SLOGON (void) { SLOG > file.log } FUNC void SLOGOFF (void) { SLOG OFF }
And to trigger it with breakpoints like:
BS main.c\123, 1, "SLOGON()" BS main.c\234, 1, "SLOGOFF()"
The trigger stuff works fine, but defining such a function aborts with syntax error:
FUNC void SLOGON (void) { SLOG > file.log } __________________________^ *** error 10, line 1: Syntax error
What do I wrong or is it not pssible at all?
Thanks for help
nobody?
this should work for you:
FUNC void SlogOn (void) { exec ("SLOG >C:\\Temp\\slog.log"); } FUNC void SlogOff (void) { exec ("SLOG OFF"); }
