Hello, what im trying to do is reverse engineering unknown device. What i need is catch a 16bytes data from it. Each clk's pulse speed is about 20 nanoseconds. I'm using stm32f4 discovery board, so i should be able to catch it as stm32 powerful uC. The fact that im really new in Keil, and i dont know if im doing it a propper way, for example to detect a GPIO goes down, im using this code
while (HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_7) == 0){}
Is it proper way to do it? THe whole code with comments are:
while (1) { uint8_t collect_bits = 0; char string_array[21] = {0}; // HAL_Delay(200); while (HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_9) == 0){} // wait until GPIOC 9 goes high while (HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_9) == 1){} // wait until GPIOC 9 goes low for (int i = 0; i < 8; i++) // make a loop for reading byte { while (HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_7) == 0){} // wait until clock goes high int32_t current_bit = HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_9); // READ bit on PINC 9 collect_bits |= current_bit << i; // Shift current_bit to position i and // put it into collect_bits using bit wise OR while (HAL_GPIO_ReadPin (GPIOC,GPIO_PIN_7) == 1){} // wait until clock goes low, then repeat while loop untill we collect 8 bits } sprintf(string_array, "%X", collect_bits); // just simple convertation for PC output CDC_Transmit_FS((uint8_t*)string_array, sizeof(string_array)); // print result. // //break; /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ }
The problem is that output is not correct.What am i doing wrong? thanks
Is this thread for real?
It was until some random a-hole drowned it in click-spam. This happens entirely too often on this forum, most likely because it totally lacks user identification.
