I am using Keil 5.25.2.0, STM32F103C8 bluepill board and J Link EDU for debugger.
I want to use keil rtx rtos because its System and Thread viewer. But when i use RTX5 it is not working.
I am creating project using keil new project wizard. Below i atteched a image for that;
i.hizliresim.com/LbmRbb.png
(Can't see picture in here?)
I can compile without any error my project. I create one or two thread(s) for testing porpuse. But when i enter the debug mode;
i.hizliresim.com/qGVNy3.png
I dont understand. I am not doing anything special like port/ping remaping for swd/jtag debug pins.
I followed www.keil.com/.../jLink_STM32F10xxx_SWT.htm and still i note getting any different.
But there some thing tricky i belive;
At www.keil.com/.../jLink_STM32F10xxx_SWT.htm it shows that when i create an ini file for STM32F10x and insert that from Options for Target — Debug ---> conf_STM32F10xxx.ini into the Initialization File field after enable trace i should be able to set the trace port to Serial Wire Output - UART/NRZ.
But even i do every thing documents said, here is what i have;
Debug Settings: i.hizliresim.com/qGVNaD.png
SW Debug Selection: i.hizliresim.com/MdmBbQ.png
Trace Enable: i.hizliresim.com/XPm3jR.png
But if i use RTX (not the RTX5) every thing is perfect.
What am i missing?
BTW i am new at the keil rtx rtos. I want to use rtx5 beacuse its api more easy to use then rtx.
Here is my answer www.keil.com/.../uv4_db_dbg_scvd_viewer.htm
Why i did not see it before? I spend about 2 days for solve this.
it would be always better to check what have been documented before trying around
