Hi, I am working on STM32F407 discovery board . I am using STMCUBEMX for using the HAL drivers. It is working fine.
I am working on ADC to read the battery voltage . I have used STMCUBEMX for creating the ADC configuration.
The configuration code has generated successfully.
I have changed the main function code as per this to read the battery voltage. I have declared BAT_Output and adcval as global varibles
uint32_t adcval;
float BAT_output;
int main(void) {
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */ SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */ MX_GPIO_Init(); MX_ADC1_Init(); /* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */ /* USER CODE BEGIN WHILE */
while (1) {
HAL_ADC_Start(&hadc1); adcval=HAL_ADC_GetValue(&hadc1); BAT_output=(adcval*2.988)/256; HAL_Delay(1000);
The above code is working fine by declaring the BAT_output and adcval as global. The battery value is coming BAT_output=2 with adcval= 185.
ISSUE 1:
But when I use the BAT_output and adcval as local varibles to main() function it is showing garbage value BAT_output=1566577.6 and adcval=134218167
Here is the code snippet of main.c
int main(void) { float BAT_output; uint32_t adcval;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
What is the real problem. Is it with keil compiler setting or anything code bug with STMCUBEMX.
ISSUE 2:
The same issue comes when I create seperate function for the battery voltage. Here is the seperate file created for battery voltage reading.
#include "main.h" #include "stm32f4xx_hal.h" #include "stm32f4xx.h"
ADC_HandleTypeDef hadc12; extern uint32_t adcval; extern float BAT_output;
float bat(void) { HAL_ADC_Start(&hadc12); adcval=HAL_ADC_GetValue(&hadc12); BAT_output=(adcval*2.988)/256; HAL_Delay(1000);
return BAT_output;
Here is the main.c file for issue 2.
float BAT_output; uint32_t adcval; float bat(void); float BAT_output;
while (1) { BAT_output=bat(); //HAL_ADC_Start(&hadc1); //adcval=HAL_ADC_GetValue(&hadc1); //BAT_output=(adcval*2.988)/256; //HAL_Delay(1000);
Can any one sort out this problem.
