My question is if it is possible, using MDK ARM Keil IDE, to define exact start location for every source code file ? I know I can define per variable location, as well as per function location, but it can be big job if I want all the vars and functions in some source code file to start from some address.
You can use the Scatter File to direct data from specific object files (ie MAIN.O) to specific regions.
If you want to group things together, use a structure.
