Dear all,
I'm trying to check the register values in inline-assembly in c as the below code. In especially, R0 and R1 values what I want to know which value is loaded to register. But as you can see that code, that is a In-line assembly.
Is there any way to check the register which values are loaded?
main.c
... __asm void ST0(void) { MOVS R0,#0 LDR R1,[R0] ; Get initial MSP value MOV SP, R1 LDR R1,[R0, #4] ; Get initial PC value BX R1 } ... int main (void) { ST0(); return 0; }
Use a debugger and step the code?
It's impossible.
