I have a program which exists out of a few files. I have my main.c file, my own library .c and .h files, I have an I/O.h file which only contain #defines and lastly I have my register.h file for the uController. The register.h file is included in my own library.h file because the library needs to know most registers.
When I ported from sdcc to keil I experienced some difficulties and enlisted Keil's help. They made some minor modifications with those overcomplicated # statements. This helped me finishing my program. Now I am porting another program which uses a few registers and I am running against linker error L104 again and I can't get rid of it.
main.c includes librabry.h and library.h includes register.h
#ifndef AT89x51_H #define AT89x51_H /* BYTE addressable registers */ sfr P0 = 0x80; sfr SP = 0x81; sfr DPL = 0x82; // many more #ifdef _COMMUNICATION_FUNCTIONS extern unsigned char xdata tpdoid = 0x8500; extern unsigned char xdata tpdo0 = 0x8501; extern unsigned char xdata tpdo1 = 0x8502; extern unsigned char xdata tpdo2 = 0x8503; extern unsigned char xdata tpdo3 = 0x8504; extern unsigned char xdata tpdo4 = 0x8505; extern unsigned char xdata tpdo5 = 0x8506; extern unsigned char xdata tpdo6 = 0x8507; extern unsigned char xdata tpdo7 = 0x8508; extern unsigned char xdata rpdoid = 0x8510; extern unsigned char xdata rpdo0 = 0x8511; extern unsigned char xdata rpdo1 = 0x8512; extern unsigned char xdata rpdo2 = 0x8513; extern unsigned char xdata rpdo3 = 0x8514; extern unsigned char xdata rpdo4 = 0x8515; extern unsigned char xdata rpdo5 = 0x8516; extern unsigned char xdata rpdo6 = 0x8517; extern unsigned char xdata rpdo7 = 0x8518; #else unsigned char xdata tpdoid _at_ 0x8500; unsigned char xdata tpdo0 _at_ 0x8501; unsigned char xdata tpdo1 _at_ 0x8502; unsigned char xdata tpdo2 _at_ 0x8503; unsigned char xdata tpdo3 _at_ 0x8504; unsigned char xdata tpdo4 _at_ 0x8505; unsigned char xdata tpdo5 _at_ 0x8506; unsigned char xdata tpdo6 _at_ 0x8507; unsigned char xdata tpdo7 _at_ 0x8508; unsigned char xdata rpdoid _at_ 0x8510; unsigned char xdata rpdo0 _at_ 0x8511; unsigned char xdata rpdo1 _at_ 0x8512; unsigned char xdata rpdo2 _at_ 0x8513; unsigned char xdata rpdo3 _at_ 0x8514; unsigned char xdata rpdo4 _at_ 0x8515; unsigned char xdata rpdo5 _at_ 0x8516; unsigned char xdata rpdo6 _at_ 0x8517; unsigned char xdata rpdo7 _at_ 0x8518; #endif sfr cogw = 0x94; // many more
The Linker only complains about:
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: RPDO7 MODULE: .\Objects\preStresser.obj (PRESTRESSER)
Only the rpdo and tpdo give problems. If I out-comment the top ones (with extern) I get ' undefined identifier error in library.c and if I out-comment the bottem lines the same error appears in main.c. So I do need all of them. I did not think of this solution myself.
In SDCC I could simply include the register.h in main.c prior to including library.h like it should work IMHO. But unfortunately for me Keil is more complicated than that.
Why is my linker unhappy and how can I make it happy again?
#ifdef _COMMUNICATION_FUNCTIONS extern unsigned char xdata tpdoid = 0x8500; : : #else unsigned char xdata tpdoid _at_ 0x8500; : : #endif
So your header file contains both a set of definitions and a set of 'extern' declarations - and which gets used is determined by the setting of _COMMUNICATION_FUNCTIONS
Are you sure you are properly defining that symbol?
This is standard 'C' stuff - nothing specifically to do with Keil. You would get exactly the same with SDCC - or any other compiler.
c-faq.com/.../decldef.html
Actually, the 'extern' declarations are wrong - the initialisations will make them also definitions!
See: http://www.keil.com/support/man/docs/c51/c51_le_absvarloc.htm
In my SDCC program it looked nothing like this. I always thought that including a file simply means that the pre processor gets the text of that file and folds it open on the spot of the #include. If that would be the case in Keil I could simply include register.h before I include the library files so I wouldn't have to these complicated things I am doing now.
SDCC did exactly that. In my main.c I used to #include the register.h file prior to including the library file which used those definitions. Therefor I didnt have to include the register.h in the library file. And there was no need for #ifndef, #ifdef, #else and #endif. But I also didn't use a seperate header file for my library. I could never got that to work properly. I therefor used a single .c file which housed the function prototypes as wel as bodies. It was not verry pritty but it got the job done. So I perhaps was doing it wrong.
In SDCC the declarations looked the exact same as the sfr registers.
__sfr __at 0xdb P7; __sfr __at 0xc8 P8; __xdata __at 0x8500 tpdoid; __xdata __at 0x8501 tpdo0; // etc
I am currently still puzzled in what I must declare/define where. I do:
#define _COMMUNICATION_FUNCTIONS #include "communication_functions.h"
in communications_functions.c (my libray file)
in register.h I currently have:
#ifndef AT89x51_H #define AT89x51_H #ifdef _COMMUNICATION_FUNCTIONS unsigned char xdata tpdoid _at_ 0x8500; ; ; #else extern volatile unsigned char xdata tpdoid; #endif
This is how I got it back from a Keil Employee with exception of the volatile keyword. The main difference is the absense of "= 0x8000". As it is like this I am also getting *** ERROR L118: REFERENCE MADE TO ERRONEOUS EXTERNAL. This is why I added "= 0x8000" after the #else. That removed error L118.
I have read the links you send me and this looks interesting: "When you need to share variables or functions across several source files, The best arrangement is to place each definition in some relevant .c file. Then, put an external declaration in a header (''.h'') file, and #include it wherever the declaration is needed. The .c file containing the definition should also #include the same header file, so the compiler can check that the definition matches the declarations."
from what I make of this. Is that I need to have the extern statements be and remove the lines with _at_ to both library.c as main.c and include register.h in both files? But that does not seem right. And I can't get to work either.
So I remain in the dark here.
I have fixed the problem. It was something real stupid.
I forgot that Keil cares little for lower and upper cases sometimes. I had other variables which were written with upper cases letters. Compiler does not see it, only the linker. But the linker does not say where the "other definations" were in my program.
-_-"
"I always thought that including a file simply means that the pre processor gets the text of that file and folds it open on the spot of the #include."
Yes, that is exactly what happens.
But the file that you showed also contains conditional directives - so they also get processed.
If you want to see exactly what's happened, look at the preprocessor output: http://www.keil.com/support/man/docs/c51/c51_preprint.htm
"If that would be the case in Keil"
It is the case in Keil - it is the behaviour defined by the 'C' standard.
"I could simply include register.h before I include the library files"
That is exactly the way to do it.
"so I wouldn't have to these complicated things I am doing now"
You don't have to do them. There is some other problem.
"SDCC did exactly that. In my main.c I used to #include the register.h file prior to including the library file which used those definitions"
Again, there is nothing specific to Keil that prevents you doing that.
"Therefor I didnt have to include the register.h in the library file"
And you still don't.
"And there was no need for #ifndef, #ifdef, #else and #endif"
That depends on what you're trying to achieve. If you want to have a single header that provides both definitions & declarations (which some people like to do) then you do need to have conditional directives.
"So I perhaps was doing it wrong"
Indeed.
"In SDCC the declarations looked the exact same as the sfr registers"
But these are all proprietary languages extensions - so they are (almost?) bound to be different between different compilers.
"I am currently still puzzled in what I must declare/define where"
Then you need to spend time studying the C51 manuals, looking at the C51 examples, etc, etc
Porting from one compiler to another always requires a good understanding of both tools.
"The main difference is the absense of '= 0x8000'"
As noted in a previous reply, initialisations are not allowed on absolutely-located variables.
"I need to have the extern statements be and remove the lines with _at_..."
Yes - you should have only declarations in the header
"...to both library.c as main.c"
No!!
Your program must contain only one definition of each variable! So it must be in etiher library.c or main.c - but certainly not both!
This is standard 'C' - nothing specifically to do with Keil
"and include register.h in both files?"
Yes.
"But that does not seem right"
Why not?
No, that's not true.
The 'C' language is, by definition, case-sensitive - so Keil C51 is case-sensitive.
As was noted in your previous thread:
http://www.keil.com/forum/63381/
Links to the Manuals, App Notes, and Examples are there.
There always used to be a "Getting Started" guide. It isn't on the website any more, but try searching your installation folders for "GS51" (it used to be a PDF, but was more recently a Windows Help File - .CHM, IIRC).
See also: http://www.keil.com/books/
Specifically: http://www.keil.com/books/8051books.asp
I know very well that C is case sensitive and that Keil's compiler is also case sensitive. But the linker sure is not.
I cannot declare 2 variabeles like int a, A;. It compiles fine but the linker does not accept this and throws me error L104. This is why I said "Keil care little for upper and lower cases sometimes"
I didn't have this problem in Arduino or in SDCC
I had a memory of a command line switch to enable case sensitivity of the linker, but can't find it. I'm possibly wrong with that memory.
Worth you reading this old post:
http://www.keil.com/forum/551/case-sensitivity/
ah - OK.
But you could have been more specific - rather than just saying, "Keil".
"I didn't have this problem (sic) in Arduino or in SDCC"
There is no requirement that linkers must be case sensitive.
It's possible that it's a limitation of the OMF51 format ... ?
(Arduino uses GCC).
