Global Variables vs. Pointers in Embedded Design
I've written a few 8bit embedded systems and the codebase I inherited and have expanded is basically 80% global variables (extern volatile), and than non-global control flags and logic variables as needed.
The end result, is that you end up with a lot void() functions to modify the global variables.
The systems run fine and the software quite readable and easy to work on, but I always have that design nag in the back of my head that I should be refactoring everything and pointer'ize the next design.
I don't have any religiosity about the memory usage aspect, the static memory is there to use as much as the heap is. It's more a question of as systems get larger, I suspect maybe the globals start to be more of a hinderance than you think? I've never gotten there in program size.
Do many of you experienced embedded software programmers use pointers extensively in your 8bits systems?
I can think of three possible use cases for using pointers in C51: linked lists (which we don't use) in this system, structs in place of independent variables and then functions with pointers to modify the strucs, maybe a double pointer if you absolutely need to modify a pointer but I can't fathom a situation in building a consumer product with an 8051 (maybe building an OS...).
I get that the functions can get re-used if you pointer'ize your code, but in one sense the functions are pretty trivial and one off in the embedded systems I've built. Very application specific stuff.
A couple of you guys who are still around C51 forum, what is your most compelling (or not compelling) use case for pointers in the code you have released?
