Hello, Im working on a project using FRDM-KL25Z and using Keil uVision5. When i compile my code I keep getting the same 3 errors. I posted a link to the picture. Someone help please.
https://ibb.co/dNgAcw
AREA asm_area, CODE, READONLY
EXPORT asm_main
asm_main ;assembly entry point for C function, do not delete
main.s(37): error: A1163E: Unknown opcode main, , expecting opcode or Macro main.s(39): error: A1163E: Unknown opcode main , expecting opcode or Macro main.s(41): error: A1355U: A Label was found which was in no AREA
How about starting with an example project from Pack Installer and then compare your project with the example project ?
Means leading white space is important. You can't jam everything against the left margin the fields expect some tabulation. Look at working examples, heck even read the docs.
