RTX Critical Sections
I am trying to port a library that is working with FreeRTOS to RTX. The microcontroller is the same: STM32F4.
The library uses critical sections. I have tried using the same implementation for the critical section for RTX as for FreeRTOS(BASEPRI) but I often end up in UsageFault.
I know that RTX uses extensively the SVC in the code.
Could it be that the Critical sections should be implemented differently ?
Do you know of any other differences between FreeRTOS and RTX that could cause problems?
Best regards,
Sebastian
