Hi All,
I am implementing a software upgrade mechanism (burning a new image into a flash memory area).
The problem: I don't know how to change the load region address at runtime.
Flash contains booter and application Additionally I allocated an area for new sw application on the same flash. After burning the new sw into the allocated area on the flash, I want to run the new sw instead of the old one.
Booter already knows how to jump to the new code in the flash. The problem is that new and old code are both compiled with the same scatter loading region mapping, so when i run the new code from the new address it still uses the "old" scatter loading region, i.e. it loads my old code.
Is there a way of setting the LR address to be relative and not absolute.
Of course i can compile the new SW with new scatter mapping, but this doesn't help me, because i don't know if it will run as a "new" or "old" image.
Thanks in advance
