Dear all, I'm using LPC1768 controller. I need to use Ethernet module to develop my application. Problem is while include ETH interface from a software pack it need RTOS. But using RTOS i have unwanted problem. Is any possibilities to use an Ethernet interface without RTOS?
Thanks & Regards, Prasanth.
Yes - there are plenty of embedded TCP/IP Stacks which do not require an OS
Please provide some TCP/IP stack links without RTOS support.
You think you're time is too valuable to go use Google yourself?
Does Google - and all the other internet search engines - not work on your computer, then?
LwIP is one which springs to mind without even googling - it is widely used by many (if not all) microcontroller manufacturers in their demo board examples.
