I recently updated uVision from version 5.22 to version 5.23. Since then, I cannot get it to reload files when I modify them in an external editor. I made sure that "Automatic reload of externally modified files" is checked in the Configuration window.
Thanks, Hugo
With this issue open a Keil Support ticket please: www2.keil.com/.../silver Thanks
Thanks for your reply. I managed to get it working again by deleting the following files:
"<install_dir>\UV4\arm.prop" "<install_dir>\UV4\global.prop"
(I then had to reenter all of my settings manually in uVision.)
It seems like the upgrade process is breaking the user settings. I also find it odd that the configuration is stored in the installation directory and not somewhere in %APPDATA%. Thankfully I'm the only user on this workstation...
Hugo
Thx for sharing your solution, Hugo. I'll discuss this issue with our developer
