Reverse working of Switch
When I am executing this code, the LED is ON by default whereas it should only be ON when switch is pressed. And when I press the switch, it turns off. Can anyone please explain me, what I am doing wrong with my code.
</ #include <lpc17xx.h>
#define SwitchPinNumber 11
#define LedPinNumber 6
void main()
uint32_t switchStatus;
SystemInit();
LPC_PINCON->PINSEL4 = 0x000000; //Configure the Pins for GPIO;
/* Configure the LED pin as output and SwitchPin as input */
LPC_GPIO2->FIODIR = ((1<<LedPinNumber) | (0<<SwitchPinNumber));
while(1)
/* Turn On all the leds and wait for one second */
switchStatus = (LPC_GPIO2->FIOPIN>>SwitchPinNumber) & 0x01 ; //Read switch status
if(switchStatus == 1)
LPC_GPIO2->FIOPIN = (1<<LedPinNumber);
else
LPC_GPIO2->FIOPIN = (0<<LedPinNumber);
  • Two two things spring to mind.
    How is the switch connected? Does the port pin have a pull up and a switch that takes the line to ground or does the port pin have a pull down and a switch that takes the line to +VE ?
    How are the LEDs connected? One end tied to ground and the other to the port pin that goes high to turn it on or one end tied to +VE and the other to a port pin that goes low to turn it on?
    Consider these and consider what your code is doing.
