Dear Sirs and Madams!
I am having problems debuging following code:
void ueInitLCD(void) { // Initialization structures I2C_InitTypeDef ueI2C_NCP5623_InitStructure; SPI_InitTypeDef ueSPI_DOGM128_InitStruct; GPIO_InitTypeDef ueGPIO_DOGM128_I2C_InitStruct; GPIO_InitTypeDef ueGPIO_DOGM128_CS_InitStruct; GPIO_InitTypeDef ueGPIO_DOGM128_RST_InitStruct; GPIO_InitTypeDef ueGPIO_DOGM128_A0_InitStruct; // Initialize IC2 Bus RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE); ueI2C_NCP5623_InitStructure.I2C_Mode = I2C_Mode_I2C; ueI2C_NCP5623_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2; ueI2C_NCP5623_InitStructure.I2C_OwnAddress1 = 0x70; ueI2C_NCP5623_InitStructure.I2C_Ack = I2C_Ack_Enable; ueI2C_NCP5623_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; ueI2C_NCP5623_InitStructure.I2C_ClockSpeed = 400000; I2C_Cmd(I2C1, ENABLE); I2C_Init(I2C1, &ueI2C_NCP5623_InitStructure); // Configure GPIO pins for I2C use RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); ueGPIO_DOGM128_I2C_InitStruct.GPIO_Pin = UE_PIN_DOGM128_SPI_CLK | UE_PIN_DOGM128_SPI_SI; ueGPIO_DOGM128_I2C_InitStruct.GPIO_Mode = GPIO_Mode_AF_OD; ueGPIO_DOGM128_I2C_InitStruct.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(UE_PORT_DOGM128_SPI, &ueGPIO_DOGM128_I2C_InitStruct); // Initialize SPI RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); ueSPI_DOGM128_InitStruct.SPI_Direction = SPI_Direction_1Line_Tx; ueSPI_DOGM128_InitStruct.SPI_Mode = SPI_Mode_Master; ueSPI_DOGM128_InitStruct.SPI_DataSize = SPI_DataSize_8b; ueSPI_DOGM128_InitStruct.SPI_CPOL = SPI_CPOL_High; ueSPI_DOGM128_InitStruct.SPI_CPHA = SPI_CPHA_2Edge; ueSPI_DOGM128_InitStruct.SPI_NSS = SPI_NSS_Soft; ueSPI_DOGM128_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; ueSPI_DOGM128_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB; SPI_Init(UE_PERIPHERAL_DOGM128_SPI, &ueSPI_DOGM128_InitStruct); SPI_Cmd(UE_PERIPHERAL_DOGM128_SPI, ENABLE); // Initalize GPIO (CS - Chip Select) Pin RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); ueGPIO_DOGM128_CS_InitStruct.GPIO_Pin = UE_PIN_DOGM128_CS; ueGPIO_DOGM128_CS_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD; ueGPIO_DOGM128_CS_InitStruct.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOA, &ueGPIO_DOGM128_CS_InitStruct); // Initialize GPIO (RST - Reset) Pin RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); ueGPIO_DOGM128_RST_InitStruct.GPIO_Pin = UE_PIN_DOGM128_RST; ueGPIO_DOGM128_RST_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD; ueGPIO_DOGM128_RST_InitStruct.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOC, &ueGPIO_DOGM128_RST_InitStruct); // Initialize GPIO (A0) Pin RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); ueGPIO_DOGM128_A0_InitStruct.GPIO_Pin = UE_PIN_DOGM128_A0; ueGPIO_DOGM128_A0_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD; ueGPIO_DOGM128_A0_InitStruct.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOD, &ueGPIO_DOGM128_A0_InitStruct); GPIO_WriteBit(UE_PORT_DOGM128_CS, UE_PIN_DOGM128_CS, Bit_RESET); GPIO_WriteBit(UE_PORT_DOGM128_RST, UE_PIN_DOGM128_RST, Bit_SET); GPIO_WriteBit(UE_PORT_DOGM128_RST, UE_PIN_DOGM128_RST, Bit_RESET); lcdSendCommand(lcdInitCmd, sizeof(lcdInitCmd)); } // ueInitLCD void lcdSendCommand(const char *pcCmd, uint8_t ui8Len) { uint16_t index = 0; for(index = 0; index < ui8Len; index++) { SPI1->DR = pcCmd[index]; while (!(SPI1->SR & SPI_I2S_FLAG_TXE)); //while (!(SPI1->SR & SPI_I2S_FLAG_RXNE)); while (SPI1->SR & SPI_I2S_FLAG_BSY); } } // lcdSendCommand
When I press Ctrl+F5 to debug upper functions, I get following error: Cannot access Target. Shutting down debug session. However, I can download compiled code to target board without problems. Why is this happening?
Most likely because you are reprogramming pins used by the debugger. You don't provide the defines, so hard to see the details.
Indeed, you are right, forgot to attach pin mappings, here they are now:
#ifndef ARCHITECTURE_H #define ARCHITECTURE_H #include "stm32f10x_conf.h" #include "stm32f10x_spi.h" #include "stm32f10x.h" // ~CS (Chip Select) Pin Mapping #define UE_PORT_DOGM128_CS GPIOA #define UE_PIN_DOGM128_CS GPIO_Pin_15 // RST (Reset) Pin Mapping #define UE_PORT_DOGM128_RST GPIOC #define UE_PIN_DOGM128_RST GPIO_Pin_12 // A0 Pin Mapping #define UE_PORT_DOGM128_A0 GPIOD #define UE_PIN_DOGM128_A0 GPIO_Pin_2 #define UE_PERIPHERAL_DOGM128_SPI SPI1 #define UE_PORT_DOGM128_SPI GPIOB // SPI CLK (SPI Bus Clock) Pin Mapping #define UE_PIN_DOGM128_SPI_CLK GPIO_Pin_3 // SPI SI (MOSI) Pin Mapping #define UE_PIN_DOGM128_SPI_SI GPIO_Pin_5 #endif
PB3 is the JTDO/TRACESWO pin PA15 is the JTAG JTDI pin
You might want to do a partial remap based on whether you are using SWD or JTAG connectivity
