CMSIS DSP arm_rfft_fast_f32()
Hello, I am working on an audio spectrum analyzer with LPCXpresso54608 (Cortex-M4F).
I am working on a program to calculate the FFT spectrum of an input signal.
All the functions from CMSIS library work fine but I don't understand the length of the input and output vectors.
The ARM CMSIS official documentation is, in my opinion, a bit confusing on this topic and I'd like to share my thoughts.
Here's an outline of my algorithm:
Start with a sample buffer of length N=1024 (Skip how the samples are acquired, let's just assume they are there)
float rx_buffer[1024];
Now this is a real signal, so calculate the FFT using arm_rfft_fast_f32():
float fft_out[1024];
arm_rfft_fast_instance_f32 fftInstance;
arm_rfft_fast_init_f32(&fftInstance, 1024);
arm_rfft_fast_f32(&fftInstance, rx_buffer, fft_out, 0);
From the official documentation (www.keil.com/.../group__RealFFT.html),
I understand that arm_rfft_fast_f32() outputs an array of N=1024 floats: N/2 are the real parts and N/2 are imaginary parts interleaved, in total N/2 complex pairs.
This is only one half of the spectrum since the other half is symmetric. So the spectrum is not replicated.
Now, I want to calculate the magnitude of each complex number so I do:
float fft_magnitude[512];
arm_cmplx_mag_squared_f32(fft_out, fft_magnitude, 512);
With this, I get a spectrum of 512 points, symmetric arround the point 256. So in total, I get 256 useful points. Is this the expected behavior? I thought that arm_rfft_fast_f32() output already only half of the spectrum, thus I should end up with 512 useful points. Where am I wrong?
Cheers.
