IDE Syntax highlighting bugs
Hi there - new to the forum. I frequently encounter display bugs within latest uVision 5.23.0.0 using Toolchain MDK-ARM Version: 5.23 (everything else is V5.06 update 4).
I am constantly getting errors in the error/syntax highlighting in the IDE. I usually repair a line, but the error doesn't go away. I have to cut/paste the line(s) in order to get the IDE to make the errors disappear. Often these indicators come back too, even when there is no syntax/compiler errors. It often will highlight sections of comments (random areas) as a code error in the IDE.
Frankly, it's driving me nuts and I've often resorted to using just Keil to compile or use other tools but it's text editor is flaky. The intellisense is pretty unpredictable too. Is this a known problem? Is it just limited to the newest versions or has this been around a while?
