In recent days I am looking for a current sense transformers I will buy.
One is CST306-1A(www.kynix.com/.../CST306-1A.html)
The other is PE-63619NL(www.kynix.com/.../PE-63619NL.html)
I am a newbabie here and I am a green hand in the field of current sense transformers. So please help me make a decision. Which one current sense transformers would I choose ?
What is your idea ? Any of your ideas would be highly appreciated.
May someone would like to help ?
thanks in advance.
What made you think this was ab appropriate place to go for advice about current transformers?
Look at the forum description:
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products." http://www.keil.com/forum/
Keil do not produce current transformers!
www.catb.org/.../smart-questions.html
Forget about current sense. First consider acquiring some common sense.
Thanks for your comments. I will listen to your advice. With the help of your advice,I will make greater progress in electronic engineerings. thanks a lot.
