Hello! How can i insert necessary for me asm comands like push/pop? for example i got example from here www.keil.com/.../armclang_ref_chr1383658400125.htm
int add(int i, int j) { int res = 0; __asm ( "ADD %[result], %[input_i], %[input_j]" : [result] "=r" (res) : [input_i] "r" (i), [input_j] "r" (j) ); return res; } int main(void) { int a = 1; int b = 2; int c = 0; c = add(a,b); }
End got a error: Source\main.c(21): error: #18: expected a ")" :D .
But it was strange syntax for me. Then I do next:
int main(void) { __asm { nop nop } }
So it works well, but as sson as I add push/pop or use any registers automaticly catch error
__asm { push {lr} //!!! nop nop add r0, r1 //!!! pop {lr} //!!! }
Can i dissable this error? I'll be able to cortol stack by myself.
In first code wrong number of error string, string with error is
I'm shure that it just a one error from snowball, but this is same string with compiler error.
Looks to be using GNU/GCC format, you should perhaps check if that is supported by the Keil tools when selected as the default.
