Hi, I have a lots of problems to find out my mistakes during debugging.And Hardfault errors annoy me a lot when I use cmsis library. I have read different online sources that the best way is to check .map files.
Could you introduce me some good references to be professional at debugging and cover all kinds of errors(basic to professional)?(video pdf )
You will need a good understanding of the device(s) you are using, the language(s) you are using, the tools you are using, etc.
With embedded microcontrollers, you will also need a working understanding of electronics.
You need to have adequate test equipment, and be proficient in its use.
But the key tool is the one between your ears - you need to Observe what is happening, Understand what should be happening, and THINK about what could cause the discrepancies:
www.8052.com/.../120313
www.ganssle.com/.../developingagoodbedsidemanner.htm
