keyboard
Below is a simple keyboard program, where i need to lock in 3 numeric digits only. The user will exit the program by pressing a non-numeric key. Until then, he can press any no. of keys. the program also displays each key properly as each one is pressed.
Problem: the program is unable to lock in the 3 digits from the key board. A similar program minus the keyboard, but using internal stored data works fine. Where is the problem ? I am using 89s52 an uvision ide. Can somebody reply please ?
ENDATA EQU #70H
KEYBOARD:
MOV R0, #03H            ; PICK UP 3 DIGITS ONLY
MOV R1, #ENDATA         ;WRITE THE DATA IN TO MEMORY
KEYBOARDDET:            ; ONLY FOR NUMERIC. PRESSING 'D' RETURNS TO MAIN
MOV P1, #11111111B      ; INPUT FOR KB
;1ST ROW
CLR P1.7                // makes row 1  low
JB P1.3,NEXT1    // checks whether column 1 is low and jumps to NEXT1 if not low
MOV A,#01H      // loads a with 0D if column is low (that means key 1 is pressed)
LCALL DISPLAYKB
LJMP STORE      ; STORE DATA IN MEMORY.
NEXT1:JB P1.2, NEXT2 // checks whether column 2 is low and so on...
MOV A,#02H
LCALL DISPLAYKB ; DISPLAYKB IS USED TO DISPLAY THE DIGIT PRESSED
LJMP STORE
NEXT2:JB P1.1, NEXT3
MOV A,#03H
LCALL DISPLAYKB
LJMP STORE
;2ND ROW
NEXT3:SETB P1.7
CLR P1.6
JB P1.3,NEXT4
MOV A,#04H
LCALL DISPLAYKB
LJMP STORE
NEXT4:JB P1.2,NEXT5
MOV A,#05H
LCALL DISPLAYKB
LJMP STORE
NEXT5:JB P1.1,NEXT6
MOV A,#06H
LCALL DISPLAYKB
LJMP STORE
;3RD ROW
NEXT6:SETB P1.6
CLR P1.5
JB P1.3,NEXT7
MOV A,#07H
LCALL DISPLAYKB
LJMP STORE
NEXT7:JB P1.2,NEXT8
MOV A,#08H
LCALL DISPLAYKB
LJMP STORE
NEXT8:JB P1.1,NEXT9
MOV A,#09H
LCALL DISPLAYKB
LJMP STORE
;4TH ROW
NEXT9: SETB P1.5
CLR P1.4
JB P1.2,NEXT10
MOV A,#00H
LCALL DISPLAYKB
LJMP STORE
NEXT10:JB P1.0, GOBACK
LJMP DISPLAY                  ; press 'D'to exit the program and display 3 digits
GOBACK: LJMP KEYBOARDDET
STORE:                                  ; STORE 3 numeric digits IN ENDATA
MOV @R1, A
DEC R1
DJNZ R0, CALLDET
LJMP KEYBOARD
CALLDET: LJMP KEYBOARDDET
