we bought the sources of the file system and I think I found a bug in the sources (bug in all releases to 7.3.0) :
When there are no files in the SD card, the file system crashes in function "elink_rewind" of file "fs_fat_elink" because "el" local variable is initialized to 0 and used as pointer further.
Add the code below to fix the bug :
static ELINK *elink_rewind (uint32_t dir, ELINK_CACHE_CB *nc) { ELINK *el; el = nc->Used[nc->Depth].Oldest; if (el == NULL) { return NULL; } if (dir <= el->Info.DirClus) {
Thanks for reporting that. This function was introduced in FileSystem V6.9.0 and therefore this issue is not present in previous releases.
I don't mean to be rude, but do you people actually test what you release? What is this?
That's a bit off. Have you never released code that have contained undetected bugs?
Microsoft releases code that contains already detected bugs ;)
Most recently the failure of the last Win10 release to properly handle full-screen use on multi-monitor systems...
