I am using fle system middleware component to store some data in the RAM of LPC1768.But whenever the function fmount() is called after calling finit() function, it returns an error code of fsNoFileSystem. What could be causing this issue ?
Review what finit() is writing to the RAM blocks (which ones, and content), and then look at what fmount() is reading. It might be more apparent then what is happening.
Actually, I am not having any debugger as of now to perform the tasks which you mentioned.Although, I have ordered one but till it comes, I got to remove this bug on my own.fformat function keeps giving me fsMediaError.
You don't need a debugger output diagnostic data via a serial port. If the low level code is dysfunctional this top level stuff is going to fail.
