Today when I tried C:\Keil_v5\UV4\UV4.exe C:\Users\Win7\Desktop\Project\prj.uvprojx -i C:\Users\Win7\Desktop\abc.xml in order to create project from xml file.
I got ERRORLEVEL 12 which is "12 Device with given name in not found in database"
No idea why.
Force using command "-n STM32F417VG" will successfully create the uvprojx file, but clearly the configs in the xml file is not applied at all.
thanks!!!!
<?xml version="1.0" encoding="UTF-8" standalone="no" ?> <Project> <ToolsetName>ARM-ADS</ToolsetName> <Device>STM32F101CB</Device> </Project>
as written here http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm , this xml file has to be compliant to the schema project_import.xsd available in the directory ..\UV4
