About STM32 SPI multi slave setup
Hi, I am trying to construct a SPI network with STM32F1 MCU in a star-shaped network so that all slaves are connected directly to the master.
In a one-master-one-slave situation, it seems that the slave is usually set to software mode so that SSI=0. Since NSS will always be pulled down there is not much problem.
However, I have read from the reference manual that the SSI bit will replace what the NSS pin is receiving if I use software mode. So, if I use software mode for all the slaves, does it mean all the slaves will be "pulled down"? In that case, should I use hardware mode for a multi-slave setup, so that I can control which slave to talk to using GPIO pins from the master?
Thanks in advance
