Hello
I think this post is not perfectly suit for here, but let me share my problem since ST website's forum is slow and troublesome to use for me.
I would like to know where I can get the software pack of Keil::STM32F3xx_DFP_1.1.1. Or if there is any alternations, I would like to try as well.
I am trying to develop a device with STM32F303k8. This is so-called "Nucleo STM32F303", and I developed some applications with the board through mbed platform. Toward more time critical applications, I am setting up my environment with Keil uVision5. Keil is nicer in the point of its offline debugger and CMSIS libraries.
So, first of all I opened an example blinky project in the Keil::STM32F3xx_DFP_1.3.0 pack. I was supposed to modify the example project to build my own application. But when I changed the device option into STM32F303k8 in the "Options for Target" window, the board support files turned red and compailer said it required the software pack of Keil::STM32F3xx_DFP_1.1.1.
But the thing is I couldn't find such files in pack installer and website.
What I want to do is run some example file of STM32F303k8 with Keil uVision5. So if I do not need to install this software pack, I would like to know the other way. Or I want your advice for the matter if you know how to deal with this.
Thanks in advance.
Marchall
Hi Marchall, with MDK-ARM V5.22, that is our latest release, installed: - open the PackInstaller - select as device the STM32F303k8 - install the Keil::STM32F3xx_DFP V1.3.0 - next open the Examples-Tab and access the four examples projects provided Note: We offer a nice MDK-ARM Learning portal at: www2.keil.com/.../
Open a support ticket if there come up technical questions: www2.keil.com/.../silver
