STM32F0- RS485 communication and HardFault Handler problem
Hello everyone,
Nowadays I am working on a project that includes rs485 communication via LTC 2850 Rs485 converter and currently I am using STM32F030F4 arm microcontroller.
Also I designed another controller card which works perfectly and I would like to communicate these two controller via rs485.But There is a problem on the stm32f030f4 side.
I already programmed using C++ programming with CMSIS drivers.I didn't use any cubemx based hal drivers on it.No error occurs After I build the program.
But It seems, falling into Hardfult handler eror at Register 15 (Program Counter) when I tried to check problems using debug mode.I have been facing this problem since the last Wednesday.You can check the eror from below picture adress.
i.hizliresim.com/ZYb99A.jpg
Yesterday, I decided to create another example program using cubemx with hal drivers and It programmed flash memory correctly.There were no Hardfult_handler error and I was able to check each function which is created in main function.
Also I would like to share my project with you, therefore you can check what is wrong detaily.I use Keil uvision mdk arm ide.
The file is available in : dosya.co/.../Cekici-devresi-versiyon-1.0.rar.html
(You should click blue "Dosya indir" button to download)
Any help would be highly appreciated!
