I am trying to enable GPIO PIN interrupts using following procedure, But not getting why flags in IST itself not setting.
Please anyone point what went wrong here
my code:
NVIC_DisableIRQ(PIN_INT0_IRQn); NVIC_DisableIRQ(PIN_INT1_IRQn);
/* enbale tx interrupt, rx interrupt for module 0 */ SCU_PinInterruptSourceSelect(0x00, 0x06, 0x00); SCU_PinInterruptSourceSelect(0x01, 0x06, 0x02);
/* enable edge interrupt */
LPC_GPIO_PIN_INT->ISEL = 0x00UL;
/* enable rising edge interrupt */
LPC_GPIO_PIN_INT->IENR = (GPIO_PIN_INT_IENR_ENRL0_Msk | GPIO_PIN_INT_IENR_ENRL1_Msk );
LPC_GPIO_PIN_INT->SIENR = (GPIO_PIN_INT_SIENR_SETENRL0_Msk | GPIO_PIN_INT_SIENR_SETENRL1_Msk );
/* enable falling edge interrupt */
LPC_GPIO_PIN_INT->IENF = (GPIO_PIN_INT_IENF_ENAF0_Msk | GPIO_PIN_INT_IENF_ENAF0_Msk);
LPC_GPIO_PIN_INT->SIENF = (GPIO_PIN_INT_SIENF_SETENAF0_Msk | GPIO_PIN_INT_SIENF_SETENAF1_Msk );
/* Clear pending interrupt of pin interrupt 1*/ NVIC->ICPR[(((uint32_t)(int32_t)(0x21)) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)(0x21)) & 0x1FUL)); /* set priority for pin interrupt 1 */ NVIC_SetPriority(0x21, 1); /* enable pin interrupt - 0x21 */ NVIC->ISER[(((0x21)) >> 5UL)] = (uint32_t)(1UL << (((0x21)) & 0x1FUL));
Pon alagappan,
If you were to be presented with a piece of paper showing something like you've given, would you be prepared to look at it?
I have neither the time nor inclination to spend time reading such an awfully formatted post.
