Hi, I use Keil MDK 5.20 for ARM. I usually work with Cortex-M0, M3, and M4F MCUs.
If you use Eclipse, it has some refactoring features such as changing methods/functions names in every source files.
For instance, if I change function name foo to bar, Eclipse searches where foo is called and replace it to bar.
Similarly, when I work with Keil MDK, when I change the name of the function, I edit my header file and search where the function was called.
Does Keil support this type of refactoring features?
-Best Regards, David
Hi David
I think there is possibility to perform Replace/Replace All in uVision using search window: http://www.keil.com/support/man/docs/uv4/uv4_ut_searching.htm
Replace/Replace all isn't the same - it doesn't take into account namespaces.
When refactoring, the editor needs to know the scope of symbol names. So if it's a field in a struct, it should rename the field in the data type and in all references of that data type - but should not touch other parts of the code that has symbols with the same name.
So the editor needs to parse the source code in the same way a compiler does.
You are right.
We are working on introducing this feature but it will take a while.
or you can use the MDK-Eclipse Plugin in Eclipse IDE. This way you can edit your project files in Eclipse with all functionalities of Eclipse. I currently use MDK 4.74 and plugin is in Keil\Eclipse folder. You may have to check for the MDK version you are using.
