I am trying to import an xml for enabling a pre-processor define in the project but it fails. I dont see any error on the commandline, but the build also does not run.
XML file contents: <?xml version="1.0" encoding="UTF-8" standalone="no" ?> <Project> <CDefines>ARM_MATH_ENABLE</CDefines> </Project>
Command used: UV4.exe -b <Project filename> -i <xml_filename>
Any help for above or inputs to enable a pre-processor directive from command line is appreciated.
Why don't you use targets in the project to define different sets of defines? Then you can call these targets from the commandline using -t parameter.
Matthias
Thanks Matthias, for such a quick response.
I am not actually building it for different targets, I am only enabling/disabling some part of code. Which I want to build through some automated build scripts with different .xml's as inputs.
It would be misleading for others if I define them as different targets.
Thanks again.
Different targets doesn't require different target hardware - it works just as well for building different variants of the code with features added/removed.
The compiler doesn't care what you decide a target to be - but you can build multiple targets.
Have your build script make a temporary project file into which you substitute your own list of defines, and submit that for building.
have you solved the problem? i also have the same problem with you , is there any way to build with different pre-processor define that without muliti-target?
