I use Keil MDK 5.20. I have 2 boards.
STM32F4DISCOVERY - 32-bit Cortex®-M4F STM32F407VGT6 MCU, 1MB Flash, 192KB RAM (Max freq. 168 MHz) 32F746GDISCOVERY - 32-bit Cortex®-M7 STM32F746NGH6 with FPU, 1MB Flash, 340KB RAM (Max freq. 216 MHz)
With the 32F746GDISCOVERY, a connector P1 with the DCMI(Digital Camera Interface) signals is available to connect a camera module such as STM32F4DIS-CAM (ST order code).
Since both boards have example codes for getting data from the camera module,
I tried to plan to use OpenCV for face detection with those boards.
The latest versions of OpenCV is 2.4.13 (2016-05-19) and 3.1 (2015-12-21).
I want to use those libraries to detect faces with the DISCO boards.
Questions: How can I compile and build the OpenCV libraries using Keil MDK 5.20?
-Best Regards, David
