Hi all,
I've been testing one ethernet server device by a software client for a while. I'm using the BSD socket method. By sniffering with Wireshark, during some traffic sessions, the server send one packet with the RST flag on, so that the client has to forcibly terminate the connection. To figure out it, I tried to increase the max number N of connection requests queued into the user API "listen (sock, N)", it seems it works fine (no RST) but I don't know if it is a rielable solution.
Thank you for your support, Fabio
Refer to http://www.keil.com/support/docs/3784.htm to turn on the network debug info, which can help you to identify better why the server sent RST packet.
