#include<lpc214x.h> void init(void); void delay_ms(int); int main(void) { int i,j,k,A,B,C; IODIR0=0; A=0; B=IOPIN0; C=B^A; unsigned char c[]="I L*** NITC \n"; unsigned char r[]="I L*** EMBEDDED SYSTEMS \n"; if(C!=0) { init(); for(i=0;i<5;i++) { for(j=0;j<=12;j++) { U0THR=c[i]; while(U0LSR && 0x20); delay_ms(250); } } } else { init(); for(i=0;i<5;i++) { for(k=0;k<=24;k++) { U0THR=r[i]; while((U0LSR && 0x20)); delay_ms(100); } } } } void init(void) { PINSEL0=0x5; U0FCR=0x7; U0LCR=0x83; U0DLL=0x62; U0DLM=0x0; U0LCR=0x3; } void delay_ms(int x) { int a,b; for(a=0;a<x;a++) { for(b=0;b<3000;b++); } } ////// THIS IS MY CODE FOR DISPLAYING FIRST STRING WHEN SWITCH IS PRESSED AND SECOND STRING WHEN SWITCH IS RELEASED. nw_code.c(11): error: #268: declaration may not appear after executable statement in block unsigned char c[]="I L*** NITC \n"; nw_code.c(12): error: #268: declaration may not appear after executable statement in block unsigned char r[]="I L*** EMBEDDED SYSTEMS \n"; nw_code.c(60): warning: #1-D: last line of file ends without a newline
nw_code.c: 1 warning, 2 errors ".\disp_5.axf" - 2 Error(s), 1 Warning(s).
KINDLY SUGGEST ME A SOLUTION SOON
First important lesson is
LEARN TO POST USING CORRECT RULES
Second important lesson is
LEARN DIFFERENCE BETWEEN && AND &
Third important lesson is
LEARN TO CODE
