I am carefully following this app note apnt_271.pdf. However at some point I reach those errors below on page 10 of the app note.
.\Objects\mlProj.axf: Error: L6200E: Symbol Driver_ETH_MAC0 multiply defined (by eth_ksz8851snl.o and emac_mk64f.o). .\Objects\mlProj.axf: Error: L6200E: Symbol Driver_ETH_PHY0 multiply defined (by phy_ksz8081rna.o and eth_ksz8851snl.o).
I am using uvision ver 5.18. I suspect the note was working in earlier revisions. The middleware version I am using is V7.0.0 but the source code of the app note is V5.00.
Everything was manageable until when I integrate the network stack. with the http server. Any help is appreciated. MiKL~
Missing some defines, or adding too many files to the project?
You have selected wrong ETH driver.
I see. I had to uncheck Ethernet(API) KSZ8851SNL Thanks. Now I have it hang in hardware_init() at the line of configure_enet_pins(0); Any suggestion?
