I am using lpc1768 as my controller. I have written a code to generate PWM output on p2.4 from channel 5 configured as single edged. I am getting the result reflected in the pin as well as PWM peripheral simulation window. I want to see the waveform generated and so i need to get it in the logic analyzer window. How can i get the PWM output waveform in the logic analyzer window.
Have you enabled the trace of your target device? http://www.keil.com/support/man/docs/uv4/uv4_using_la.htm
Thank you for the reply. I am not using any debugger hardware. I am using only the simulator. And am talking about how in the simulator PWM waveform can be shown.
Thanking you, With regards, -------------------------Biplab Roy
