hi, im using a 8051 uC to post to a thingspeak.com/ channel using a SIM900 GSM modem. i used the following commands. AT+SAPBR=3,1,"Contype","GPRS" OK AT+SAPBR=3,1,"APN","WWW" OK AT+SAPBR=1,1 OK AT+SAPBR=2,1 +SAPBR: 1,1,"100.119.182.199"
OK AT+HTTPINIT OK AT+HTTPPARA="CID",1 OK AT+HTTPPARA="URL","">api.thingspeak.com/update" OK AT+HTTPDATA=188,10000 DOWNLOAD
ERROR AT+HTTPACTION=1 OK
+HTTPACTION:1,400,1
i have no idea why i am getting a error after i transfer the POST request data within 10 seconds after the AT+HTTPDATA command.
The POST request looks something like this. POST /update HTTP/1.1 Host: api.thingspeak.com Connection: close X-THINGSPEAKAPIKEY: i use the write key for my channel here Content-Type: application/x-www-form-urlencoded Content-Length: 14
field1=150
Can someone please help? TIA
"Connection: close" --> you probably should check why your TCP connection is closed
