I have added U postfix to the integer but the problem still is the same.
I read following pages but didn't work. http://www.keil.com/support/docs/3243.htm http://www.keil.com/forum/14703/
#define M(x) (u32)(1U << (x%32)) enum{ eFirst = M(x) ..... eLast = M(31) // generate "integer operation result is out of range" }
Can I avoid this warning?
You should be able to cast it as an int to get rid of the warning.
(int)(1U << 31)
You'll want to make sure that it's actually doing what you want though.
Unfortunately the OP was considerate enough to reduce detail to a minimum and miss the selection of his toolset.
So, typecasting to int on C51 ain't gonna help none.
But would C51 support long enum values?
Wouldn't it be likely to complain already at M(15) (requires unsigned) or possibly M(16) (requires long)?
Try this expert bit of code
<code> #define M(x) (uint32_t)( ((uint32_t)1) << (x%32)) </code>
Lots of parentheses in your #define.
Now try M(35-32) and see if you are happy with your parentheses.
yes but I just try to fix the warning hes seeing. here it is with your problem fixed.
<code> #define M(x) (uint32_t)( ((uint32_t)1) << ((x)%32)) </code>
no charge this time.
Thanks for your replies,
I had tried the followings, Keil generates the warning.(Keil v5.16a)
typedef unsigned int u32; 1) #define M(x) (u32)( ((u32)1) << ((x)%32)) 2) #define M(x) (u32)( (1U) << ((x)%32)) 3) if I write also (u32)0x80000000 instead of M(31) in enum #define L(x) (u32)((1U) << ((x)%32)) #define T() ((u32)0x80000000) #define M(x) (u32)(((u32)1) << (x%32)) enum{ test_1=M(31), test_2=L(31), test_3=T(), }; compiling Gprs.c... ..\src\Gprs.c(14): warning: #66-D: enumeration value is out of "int" range test_1= (31), ..\src\Gprs.c(15): warning: #66-D: enumeration value is out of "int" range test_2= (31), ..\src\Gprs.c(16): warning: #66-D: enumeration value is out of "int" range test_3=
The implementation is free to choose the underlying type of an enum, but it must cover all values given.
Probably keil choose int and are letting you know your values are too big for what it wants.
You could consider defeat and use a series of defines.
You're right, I had already changed, maybe It would be a good option of Signed/Unsigned enum while define it because I didn't get warning on some compilers.
