I am using Keil uVision4, and ULINK2, but I am not working on development right now only flashing boards.
Is out there a simpler Keil SW tool to only Flash *.HEX files in to a Freescale ARM CortexM MK60DN256xxx10.
Perhaps not specifically Keil but something that you can recommend me to use compatible with the ULINK2.
Thanks,
And you can't use the .ELF that created the .HEX?
Keil doesn't provide any stand-alone utilities. You want something like that, consider Segger J-Link. Does Freescale provide any low cost solution? ST has the ST-Link + Utilities
http://www.keil.com/support/man/docs/uv4/uv4_fl_hexdownload.htm
