My problem is as following. I have a string array, If I delete last string of GprsErrors or pointer of GprsErrors, if I make const pointer. I don't get error.
I'm using some static addresses(0x20000309, 0x20000308 .....), I guess, Keil is trying to write static address so I get the following error.
Keil shows as fgetc_b.o and constant.o overlap, I didn't find the source of the problem.
what is my fault? or How can I find and solve the problem?
Thanks alot.
Kutay,
..\Output\Project.axf: Error: L6971E: fgetc_b.o(.data) type RW incompatible with constants.o(.ARM.__AT_0x20000309) type ZI in er RW_IRAM1.
char const * GprsErrors[]={ "BAUDRATE", "AT CMD", "ATE0 CMD", "BAT INIT", "PIN CODE", ..... ".....", // I'm deleting this string and I get no error(everything is ok) };
