string pointer and static address problem
My problem is as following. I have a string array, If I delete last string of GprsErrors or pointer of GprsErrors, if I make const pointer. I don't get error.
I'm using some static addresses(0x20000309, 0x20000308 .....), I guess, Keil is trying to write static address so I get the following error.
Keil shows as fgetc_b.o and constant.o overlap, I didn't find the source of the problem.
what is my fault? or How can I find and solve the problem?
Thanks alot.
Kutay,
..\Output\Project.axf: Error: L6971E: fgetc_b.o(.data) type RW incompatible with constants.o(.ARM.__AT_0x20000309) type ZI in er RW_IRAM1.
char const * GprsErrors[]={
    "BAUDRATE",
    "AT CMD",
    "ATE0 CMD",
    "BAT INIT",
    "PIN CODE",
     ".....",       // I'm deleting this string and I get no error(everything is ok)
  • First off - think about the difference between a pointer that is const and may not have the pointer value changed, and a pointer that points to const data that may not have individual characters changed.
    Secondly - you several times writes "deletes" but never show us what code you have that tries to delete any string.
