I am using the command line to allow me to create batch files to build my projects. The build command (-b) is working correctly. However I would like to clean the project first. In the documentation (http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm) the example shows this 'UV4 -c PROJECT1.uvprojx' so I am doing 'UV4 -c Vick4610MCI.uvproj' (interestingly my project isnt a uvprojX.. i assume this is version 5?). But when I run this instead of cleaning the project it launches uvision!
An ideas why this is happening? Also are there other undocumented commands that can be used? Like a 'Rebuild all target files'?
Many thanks.
Yes, it always launches uVision to build, rebuild or clean a project. After invoking uVision this way, all LST and OBJ files should be deleted and uVision closes automatically. If uVision should not be visible, you can use -j0 in the invocation line. See http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm for more details.
I don't believe this is correct. When I do a build using the -b command uVision does not really open, just the build window appears and closes at the end. However using the -c command the whole uVision IDE starts up with the specified project and does nothing else. It does not clean it.
I have currently got around this problem by doing a windows 'del .\Objects\*.* /q' which is working fine for me, so might help others. I would still be interested to know why -c does not work though!
I just checked this again with a *.uvproj project file (not *.uvprojx) and it works as expected. As long as you don't specify -j0 uVision always opens with all windows and after the job is done, it closes automatically. If you have a small project maybe not all windows are updated before the build-process is executed. I don't know why you only see the build-window.
Can you duplicate this issue only with your project or also with one of our standard examples? What uVision version do you use and for which processor core?
MDK 4.11 is 5 years old. I am sorry but I don't have such an old version installed on my PC to duplicate this problem. Since I tested this with the latest version I am quite sure that it works now. Can you use the latest version 5.17? As far as I see, your license allows this.
Yes it appears to do the same with the 'Hello' example. My batch file for that is this:
UV4 -c Hello.uvproj UV4 -b Hello.uvproj
The first line launches the IDE with the Hello project then nothing happens. I then manually close the IDE and the second command in the batch file starts which successfully builds the project but only showing the build output window (not the whole IDE).
I am using: uVision: V4.03q Toolchain: V4.11 C Compiler: V4.0.0.728 CPU DLL: V4.11 Dialog DLL: V1.16a Target DLL: V1.56 Dialog DLL: V1.13
There is no need to test the old version, since -c clearly is a feature that first appeared in 5.16, see: http://www.keil.com/support/man/docs/uv4/uv4_rev_hist516.htm
This explains a lot, thanks for confirming. I will continue with my batch file 'del' command.
Thanks.
