uVision 4 Command Line to Clean not working
I am using the command line to allow me to create batch files to build my projects. The build command (-b) is working correctly. However I would like to clean the project first. In the documentation (http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm) the example shows this 'UV4 -c PROJECT1.uvprojx' so I am doing 'UV4 -c Vick4610MCI.uvproj' (interestingly my project isnt a uvprojX.. i assume this is version 5?). But when I run this instead of cleaning the project it launches uvision!
An ideas why this is happening?
Also are there other undocumented commands that can be used? Like a 'Rebuild all target files'?
Many thanks.
