Hi, I have question regarding the testing of USB device. As we test UART on Hyper Terminal, what tool can we used to test the USB device? i am working on LPC1768. thanks in advance
Wouldn't that depend on what functionality you have developed software support for?
If your device supports a USB memory stick, then a USB memory stick would be a good way to test the SUB.
If your device supports a serial port over USB, then the Hyper Terminal would be a good way to test.
Only you would know what is meaningful, since only you knows your requirements specification.
Thanks a lot @Per Westermark
