HTTP with file system
I found out Keil Embedded File system does not support opening more than 2 files at the same file.
I have unit test to prove it now.
Is this limitation with Embedded File system?
We have more than 2 HTTP sessions. these HTTP session trying to open more than 2 files simultaneous using fopen. then browser HTTP Get request fails for some files.
I try setting
File : File_config.c
Embedded File System
Number of Files > 3
If I try opening more than 3 files at same time. fopen hangs.
I am using External NOR Flash memory with SPI driver.
If I have only 2 HTTP sessions and Number of Files =2 then it works but browser load very slowly first time if no cache for any files.
I have few html, JS and css files.
Have Keil test their HTTP server with Embedded File System or we need to use SD card with FAT File system.
