Linker warning L16
While building a project this message appears:
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?CO?AMPL_DRIVER
I know that this warning indicates that there is a part of code
in the ampl_driver file that is excluded from the overlay process.
after searching (by commenting code parts) I found out that the warning is caused from a
constant 'ref_int_tmpr', which is declared at the 'ampl_driver' file and
is used only once in the same file and nowhere else in the project.
The constant is used by a function which is included only if defined earlier:
// global declaration:
const float code ref_int_tmpr = 40;
#ifdef __LT
  out_sig[i] = (out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain)) -
               low_temperature_correction(case_temperature,t_index,i);
#else
  if(!sensor_mode.delta)
        //signal with temperature correction
        out_sig[i] = (out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain)) *
                     ((1 + ref_int_tmpr * ID1_xram.alpha[i]) /
                     (1 + get_temp_sensor() * ID1_xram.alpha[i]));
  }//if(!sensor_mode.delta
  else
        //no temperature correction
        out_sig[i] = out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain);
#endif //__LT
When the _LT option is defined (the #else part isn't executed) the error appears.
The problem is that the warning stays also after commenting/ entering into
the define choice the declaration part:
#ifndef __LT
#endif
Any idea why?
Thanks,
Amitai
